Clubbing ultrasonic and sonar sensor together
Ishan Jain
Joined Nov 12, 2016
100
I am trying to club both ultrasonic and sonar sensor in same housing. If there is an object in range, will both the sensors interfere with each other leading to disturbance in outputs or not? If yes how can I avoid the interference of sound signals of both the sensors.
Thank you.
RichardO
Joined May 4, 2013
2,270
I don't understand what you have in mind. Can you give us some sketches of both your mechanical and electronics ideas of what you want to do?
philba
Joined Aug 17, 2017
959
And, give us the actual part numbers of your two sensors. By the way, the word "club" is probably not a good translation. I'd guess you mean "mount".
GopherT
Joined Nov 23, 2012
8,009
Thank you.
They likely will interfere but you can send 5 pulses from one sensor, wait for the echo, then 5 wavelengths from the other and wait for the echo.
Or, option 2, you can add filters if your frequencies are far enough apart, and you have access to control the gain on the receiving amplifiers, then you can run big at the same time.
Ishan Jain
Joined Nov 12, 2016
100
Thank you for your suggestions guys. But I have dropped the idea of mounting them together as the application requires only sonars. I tried MB1240 XL- MaxSonar sensor but it doesn't have a good field of view.
Can you please suggest me some sonars with higher FOV as I have to mount them on the side of my car.
Thank you.
