I know that in order for a current to flow,i must connect the load to a phase and a neutral:closed circuit.
In the picture i inserted,two three phase generator are on,the load is connected between one phase of the first generator and a phase of the second generator
My questions are:
1-What will happen to the load,will it turn on,stays off,or burn out? my opinion is it will stay off because the circuitry is not closed(no neutral connected to the load) but i need to be certain.
2-how i can take advantage from the two generators at the same time,meaning connecting more than three mono phase loads?
thank you
My questions are:
thank you
