I am currently trying to clean my place up the best I can.
(i.e I want to get it as clean as I can super clean and organized )
These are some of the problems I am having so far with cleaning
1) I have a toilet bowl that is really old and I can't get that ring around the toilet boil out. I have hidden it in the passed by using those blue toilet boil cleaner tablets. Though since I want this place to be immaculately clean it is still bothering me. As well as some of the bath tub but less so for this.
I believe the materials are porcelain and I haven't found anything that work quite yet.
Other then replacing or using some epoxy dangerous chemical to refurbish/repaint it.
2)
What is the best cleaning agent that I can get to easily remove grease stains on painted dry wall surfaces. The grease looks like a yellowish color there is not a lot of it but in one certain area near the stove appliances there is.
I know I can repaint/sand down though I don't want to go through the trouble of painting an entire room just to get grease off a wall.
Note at that particular wall area it is fairly thick tried steal wool that made it worse.
Though cleaning the oven with steal wool and oven cleaner spray worked like a god-sent.
3) Those 2 above questions are my main problem but also am curious about these last items that I clean very successfully usually but would want your take on what you think is the best stuff to use to clean these items/appliances.
1) wood staines on finished and non finished wood products like tables chairs , dressers,...etc
2) fabric staines on couches , sofa chairs ,... and other fabric based furniture
3) plastic stains on plastic based items currently I just use an SOS pad with soap water and find that this is the best way but you may have a different opinion... also sometimes I use a bleach based cleaner.
4) metal stains on metal based items mostly in the form of rust ?
5) glass stains on glass based items I normally use windex or rainx or soapy water but curious if you guys have any thing different in mind.
Also curious if you could use rainx to clean your glass you drink out of I would think not and just use soap for drink wear obviously... Though I wasn't sure if you wash them after it would be ok.
These questions all pertain mostly in my case for the home though if some of your cleaning methods work more generally for outdoor products that is cool to but focus on products/cleaning methods within a place like a home,apartment , or building.
2)
