Cleaning Corroded wires ?
Rufus Chucklebutty
Joined Mar 23, 2019
70
Is there any method to clean the end of multi stranded copper cable that has gone black with corrosion when you can't just cut it back ?
This is to repair connections on old devices, tools, power leads, appliances ect either by crimping or soldering , I'm thinking an acid dip or specific type of flux ?
28,412
I have had a bit of luck sometimes with mechanically scraping off some of the black. And at one time I had a roll of RADIO SHACK brand solder that would work on wires that were brown, not black yet. So some non-acid solder flux types work a lot better than other types.
