Classic home made simple lead/acid Battery charger
frpr666
Joined Feb 2, 2010
53
I think the 15V transformer is all right. As above written Vpeak=15x1.414=21v. Imagine if the transformer was about 0.1 internal resistance and the current was 40A, then you would get 4V drop. It is quite normal. In addition diode drop would be on 2 diodes x 0.7V= 1.4V. Then the peak voltage on output would be 21-4-1.4=15.6V. The SCR1 is opening and closing itself at rate 100Hz. If the voltage across the battery becomes high enough then the SCR2 will open and blocks further opening of SCR1.
Axel Stone
Joined Apr 8, 2015
12
guys, i am working on another circuit that is more simple, just a relay, transistor, and a zener diode , i will post it later :)
Axel Stone
Joined Apr 8, 2015
12
what do you mean by mesuring the voltage accross the battery ?
i thought to move Vr behind the relay so i can charge different batteries( Vr is a Potentiometer)
correct me if i am wrong, even if we give a battery 15v , it would absorb only what it needs to recharge right ?
and i will remove the filter from the circuit.
also i have few questions, if the transistor's base is 5v , should the zener diode be 5v ? and where can i find a catalogue or list that has transistor and zener diode specifications.
the zener diode i will use is triggered at 13v and regulates it to 5v the same as the transistor for example.
frpr666
Joined Feb 2, 2010
53
When I'm looking at the original schematic on page 1, It is pretty clever. It measures the voltage across the battery (R2,C1,VR1). If the voltage is high enough it will activate the SCR2 that remains opened (and stops further charging). It is very important! Your last schematic is wrong. Your version with the transistor doesn't switch on and off depending on the battery voltage.
Axel Stone
Joined Apr 8, 2015
12
Hello my friends, sorry if this is too late, but only now i got the time for this :
after doing simulation on isis proteus, it didn't go well any suggestions ?
D5 is 5.1 zener 1.5w
Q1 is a 80v 30A transistor
Q2 is 40v 0.5A transistor
1) here in the first picture, i get 13.4 v to the battery, after the divider it's 5.07, D5 is 5.1v zener, but i get 0.13 after it ?
2) here when the battery has 14v, and after the divider it's 5.2v, and still the led D4 doesn't turn on ? also if i put voltmeter on Q2 there is always the same voltage across the battery
3) this is the final joke :p
guys i want to use regulators like the lm318 or l200 which are very easy to use, but they are only for low current 3A or 2A , does any of you know which one i can use for high current ?
Axel Stone
Joined Apr 8, 2015
12
i changed q2 to be in right position, but always still the same case
am asking please can i go ahead and build this ?
which program can i use to simulate a charging battery ? all i can find in isis is a source battery :( i just change it's tension
i tried to replace it with a super capacitor but didn't seem to work either.
5 amp don't seem like enough for me
