Class D amplifier as a current source
pleriche
Joined Oct 29, 2017
99
It's easy to configure a buck regulator as a current source, but is it possible to do the same with a commodity low to medium power Class D audio amplifier, and if so how?
My application is a neck loop for induction coupling to my hearing aids on the telecoil setting. The loop will have a resistance of a small fraction of an ohm and I need to drive 300-500mA RMS through it, powered as efficiently as possible from a battery.
Ian0
Joined Aug 7, 2020
13,228
Maybe you could put a resistor in the ground connection of the loop and connect that to the feedback pin.
I can't guarantee that the loop will be stable.
38,688
I think so.
Just put a small resistor in series with the loop, perhaps an ohm or so.
You will need to keep the signal level low to the amp input to avoid overdriving it.
Then the output only needs to be about 0.5Vrms (1/4 Watt) to generate 500mArms through the loop.
For 500mArms, the amp only needs to be rated for 2W into an 8 ohm speaker.
A 5W amp should be more than sufficient.
28,029
The neck loop needs to have quite a few turns of wire, not just a single turn. That is because usually the power available to drive such a loop is not large.
pleriche
Joined Oct 29, 2017
99
Roughly what I had in mind. But I haven't found a open loop Class D amplifier.
pleriche
Joined Oct 29, 2017
99
I think so.
That would probably work, but it's still a voltage drive, with the load impedance well below spec and the resistor will waste battery power.
pleriche
Joined Oct 29, 2017
99
Which is why I want a Class D current source. I tried a piece of 26 way telephone cable with all the cores in series but the results were very indifferent and it was bulky and not very flexible.
38,688
True.
But the spec is for delivering maximum power to the load, not that the amp can't work with a lower impedance.
Then use a lower resistor value (any current source still needs a resistor in series with the load to regulate the current).
Just attenuate the input to avoid overdriving the amp.
The amp should have built-in protection so it won't blow with a low impedance load.
pleriche
Joined Oct 29, 2017
99
True.
Certainly no decent amp should blow, but if it shuts down instead the only practical difference is you don't get the smoke and the bad smell. And you can savour the frustration multiple times. But also consider: if it's only spec'd for a 4Ω load there's no guarantee it'll be capable of supplying the required current at a very low output voltage.
38,688
Since you don't need a lot of current, I doubt that would be a problem.
But if you don't think it will work, then I'm out of options. :rolleyes:
38,688
It likely shuts down from excess output current, not too low an output voltage.
And you load will not draw excess current if you properly control the input signal amplitude.
28,029
Multi-pair Phone cable is not even in the same state as the actual neck loop cables, neither gage nor flexibility-wise.
And why the fixation about amplifier output impedance? Matching is to maximize power transfer, but transferring power into a resistor is a waste. Always!, in this sort of application.
