Class d amp circuit info
SuperGiachi123
Joined Aug 28, 2017
Hello, i want to build a class d amplifier from scratch. This amp will be used in an home made portable speaker, so efficiency is key. I'm looking at around 30-40 watts output ( i know that it is overkill for a portable speaker, but the speaker will be quite large and i may use it as a desk speaker sometimes.)
I'm a newbie in electronics, so i need someone to guide me through the process of designing the circuit and the pcb ( i will use easyeda because i don't want to etch my own pcb).
I did some research and found out that i could choose an integrated IC that does all the work or use separate components.
Which one will suit my project the best?
Thanks in advance.
JohnInTX
Joined Jun 26, 2012
4,787
As a newbie, you might consider starting out with one of these:
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=tpa3116
Cheap and done.
If you want to roll your own from a class D amplifier IC like the TPA3116, have at it. Pull the datasheets and the manuals for the available evaluation boards from here:
http://www.ti.com/sitesearch/docs/universalsearch.tsp?searchTerm=tpa3116#linkId=1&src=top
I've found that most of the cheapie Chinese units from Amazon conform pretty closely to the evaluation board's circuit for a given amp IC and PC layout for many $$ less than the board from TI. I use one in a home-rolled guitar amp.
A review of the block diagram of the TPA3116 or similar Class D chip will probably dispel any notions of rolling your own instead of using one of those nice ICs.
Have fun!
Edit: @crutschow beat me to it.
SuperGiachi123
Joined Aug 28, 2017
Thx for the answers.
Even if i am a newbie, i'd like to build the circuit, even if i don't fully understand it.
I read a bunch of datasheets and i understand most of them. The problrm is that i don't know hot do draw the schematic and how to design the pcb.
By the way which IC is best for newbies?
