A 1/8 stereo input. My girlfriend made me put away the project for tonight. Ill look into what you noticed tomorrow.2.2meg photo, did you carry your red over to the power section? The black cable is in the way and the white jumper seems to be in the wrong row.
No. I see it in the 5th photo.
What are you using for audio input?
I've used two wall-warts back to back when I've needed a bipolar supply. Wall warts are like coat hangers; they spontaneously reproduce in my closet.No can do unless you create a, "fake" ground at the middle of a 12 volt supply and use that for the ground symbols at the inputs of the two op-amps. Both of them require very little current, so you can just use 2 resistors and a capacitor to make the voltage at the middle hold still. Say...10k ohms each with a 10 uf capacitor connected to the most negative voltage of the wall wart.
Got it?
So in the 5th photo you saw the white jumper and it is in the correct location? Also does the 1/8th stereo input have anything to do with it?2.2meg photo, did you carry your red over to the power section? The black cable is in the way and the white jumper seems to be in the wrong row.
It is ultimately up to you to measure the voltage at the collectors of the power transistors because you can see this better than I can, and you can measure it, while I completely can't (measure it).So in the 5th photo you saw the white jumper and it is in the correct location? Also does the 1/8th stereo input have anything to do with it?
No its rectified, It means its around 24Does 24~ mean the output of the supply is AC?
The voltage at npn collector is at 23.72 and pnp is at 23.4.
/QUOTE]
That is definitely wrong. The collector of the PNP transistor should be "ground" or your most negative voltage.
This indicates a missing connection from the ground side of the power supply.
The power transistors require heatsinks for when you get it working.and I would really appreciate it if you see anything obviously wrong
So don't spin it past that point.when i spin the 10k pot past a certain point, the sounds stops until i reset the power.
