Clarification of Relay markings and voltages
paul28
Joined Aug 27, 2024
18
I have an unbranded generic model JQX-13F LY2 relay that is marked as 12A 240 VAC / 28VDC on the clear plastic casing enclosure to the coil. The coil plugs into the terminal base via connector pins. The coil is marked as 220/240 VAC on the white plastic coil wrapping. The terminals are 8 (+ve) and 7 (-ve) for the coil, N/C 6-2 and 5-1 and N/O 6-4 and 5-3.
Does this mean the coil must be energised using a 240V AC power supply and that the limits for the current rating of the non coil terminals and pins and their associated wiring inside the relay and base are either 240VAC or 28VAC depending on whether these are taking DC or AC loads through them. In other words it is an AC energised coil for the switch to control either AC or DC signals/power so to speak. The difference between the VAC and the VDC is to do with limits for arcing across terminals.
Any help on this would be appreciated.
Many thanks
Paul
paul28
Joined Aug 27, 2024
18
View attachment 330202View attachment 330203
Many thanks
Paul
panic mode
Joined Oct 10, 2011
5,485
i used to work with LY and very similar MY relays quite often.
unfortunately that part number is not complete...
LY2 is just a product family, not a specific product within family.
the JQX-13F is the pinout information
The LY2 is the DPDT series.
the rating value printed on front clear cover is for the contacts.
the rating value printed on the coil is for the coil
the +/- info next to coil contacts only has meaning of this is a DC coil.
Note: relay coil itself is of course not polarized but on DC models polarity does matter when indicator LED and suppression diode are present.
check this:
http://www.langirele.com/htm/general-purpose-relay-ly.htm
your relays full part number should be JQX-13F LY-2 AC240V S
paul28
Joined Aug 27, 2024
18
check this:
Thank you. That answers my queries and confirms what I thought.
One last matter. The plug in base for the relay is not marked with terminal numbers. Would the below interpretation be correct or should the positions of 8 & 7 and 6 & 5 be swapped? i.e. Configuration A or B. (see below).
Many thanks
panic mode
Joined Oct 10, 2011
5,485
i do not understand the question.
also why are you posting images that are upside down or flipped/mirrored? texts in pictures need to be readable.
and why don't you post actual part numbers or whatever is written on it?
if you want others to help you, you need to make the first step yourself. a bit of photoshop done correctly goes long way...
this is how it looks like when mirrored back and rotated so it is oriented correctly. now one can see and read PTF08A on it....
next step is to justs google it and find datasheet. note the fat lines representing socket connections (six horizontal and two vertical slots, top view). they are oriented in the datasheet the same way one is supposed to look and read the label on the actual socket. is this what you are after?
terminals 1 and 2 are not visible from this angle
so i turned your drawings the proper way (so that relay connections match the orientation used by me and the datasheet).
it is clear that both of them are wrong. you got the din rail clip release on the bottom but images are still mirrored horizontally and terminals 1 and 8 are not kitty corner from each other.
28,626
As for the relay ratings, it is indeed a relay with a 220/240 volt coil and the claimed contact rating is 12 amps, with 240 volts AC or 28 volts DC.
paul28
Joined Aug 27, 2024
18
your configuration B is the closer match....
it can be fixed like this
Many thanks for this.
I was trying to be helpful by flipping the base because the relay in the photo on the vendor's site was not orientated the same way around as the base as you can see below:
Please note I had already asked the vendor for the data sheets but had not had a response. I had not realised the number on the base was a part number. Its the one thing I hadn't search for on the net.
So again a great big thank you for your help.
Hopefully now I can get my circuit to work. If not I am sure I'll be back to request more help and advice.
panic mode
Joined Oct 10, 2011
5,485
looking at things in correct orientation reduces chances of mistakes.
normally in electrical panels devices are mounted like this with release tabs at the bottom:
datasheets show products in such orientation as well:
compare that with some of images...
this is how it should be, top view, release tab at the bottom, label readable...
and then there are some others. human brain can compensate to a degree but it is clearly demanding more effort and increases chances of mistakes.
if other post had attachments like that, they would look something like this o_O
MaxHeadRoom
Joined Jul 18, 2013
30,887
To add to post #10, the mounting shown uses DIN rail, which many panel mount devices optionally use now, there are around three or four forms of DIN rail in use for panel building.
paul28
Joined Aug 27, 2024
18
All noted and thanks
