A 1Hz clock can be had from gutting any 1.5v battery desk or wall clock. These oscillators all generate two 0.5Hz pulses to alternatively drive the motor coil. By diode ORing these pulses you get 1Hz pulses. The internal circuit is an IC under an epoxy blob. Some are on an open frame and others are on PCBs. I've found that the outputs are either positive pulses or negative pulses. This is shown in the attaches schematics. Also a couple examples of the circuit mountings.
