Look at post #6 here http://forum.allaboutcircuits.com/showthread.php?t=23381
That will trigger upon application of the 12V pulse from the Lock/Unlock line.
If your window motors are already set up to close under those circumstances, cant you just tie into the same power that is used for those motors to close your mirrors? You could use a limit switch to cut the power off to each mirror once it has reached the closed position.Willamj, thanks for your post. No apology needed, any input is appreciated.
Whilst using the ignition to control the mirrors would be easier, it's not what I'm after. It has to tie in with the central locking system as part of what is called 'remote total closure'. My windows will close if they are open and the vehicle is deadlocked, I'd like the mirrors to fold under the same circumstances. The mirrors must then unfold again on unlocking the vehicle.
I fear using the ignition would increase the wear rate on the motor simply due to the number of times it would be active.
And what I mean by that is control the closing through the same circuit that closes the windows. Then, just design a circuit that opens the mirrors. Might prove to be easier since the mirrors need to be open when the ignition is on so you can tie in to a circuit and not have to worry about any timer circuits.Well I think it would be easier to design a circuit that accomplished the opening of the mirrors rather than design a circuit that handles both opening and closing.
Well, I've been a bit stupid I think...Look at post #6 here http://forum.allaboutcircuits.com/showthread.php?t=23381
