Circuit to add a spike to a square wave
crazyquiff
Joined Jul 25, 2024
24
I know everyone wants to remove noise and spikes from square waves but I want to add one!
12v square wave input, say 60ms period (will vary) assume ramp up is quite fast and I guess that speed will have an impact on the spike peak. I want a up to a 30v peak spike on the leading edge. I've only got 12v (14.5v at times) to play with.
Any suggestions?
I've tried simulating with and inductor and diodes and can create a spikey wave but always <12v
crazyquiff
Joined Jul 25, 2024
24
I want to drive a rev counter with the square wave. Some versions of the rev counter work on a clean sq wave. Others don't work on a clean wave. The coil normally give a spike higher than 12v which I can reproduce on a bench setup.
crazyquiff
Joined Jul 25, 2024
24
I can't as the driving signal is 12v already or 14.5v when engine running.
That's why I was considering a spike to get a higher voltage
BobTPH
Joined Jun 5, 2013
11,647
Specs of the counter, please.
Edited to add: If this is an electromechanical counter, 60 msec might be too fast for it.
35,177
Ok. This is an RPM tachometer. Does it have odometer readout?
I am going to assume that this is not a mechanical counter. My first guess is that it is a 555-timer circuit that integrates pulses to drive an analog display meter. But I could be wrong.
Next question is, what device is sending a signal to the tachometer?
Here are examples of 555-timer tachometer circuits.
crazyquiff
Joined Jul 25, 2024
24
The chip on there is a SAK215 -https://www.tekkna.it/index.php%3Fdispatch%3Dattachments.getfile%26attachment_id%3D2308&ved=2ahUKEwi3vI_jpMKHAxWuUkEAHddiOuUQFnoECCkQAQ&usg=AOvVaw3xKEM0EgGSQMCiTp7Wd2m8
panic mode
Joined Oct 10, 2011
5,250
the image shows something quite ancient. so if it was working before, something must be wrong with the unit itself. i can see that the trimmer is oxidized and electrolytic caps must be out of spec by now. i would be replacing them rather than trying to modify how the circuit is supposed to operate.
crazyquiff
Joined Jul 25, 2024
24
They do work with the standard setup, no problem - circa 1984. But they don't work with a 12v square wave. I have other versions that do work with both however.
