Circuit Review of Photodiode Detector
ericgibbs
Joined Jan 29, 2010
21,622
hi ninja,
I’ll be connecting it with will be an SMU, which also doubles as a power supply.
What is the measured voltage output of the SMU ? On and Off load ?
E
ericgibbs
Joined Jan 29, 2010
21,622
Hi ninja,
That is what my circuit is showing, a voltage output proportional to the Lux light shining on the photo diode.
E
This image section represents a photo diode.
28,485
That circuit looks reasonable, except that the supply voltage is directly tied to the ground, which, I am guessing, because it is not stated, is also the supply negative. The assumption that "ground" is always the supply return is not doing anybody a favor. Consider that especially for beginners, all of a circuit should actually be shown. AND, consider also that seldom is "a ground" the noise-free zero resistance connection that it is always assumed to be.
And if the TS is interested in experimenting with photo-diodes, consider that some LEDs produce over 100 millivolts when light illuminates them. And some LEDs do not.
ericgibbs
Joined Jan 29, 2010
21,622
hi Bill,
Stop guessing and carefully read the TS's posts.
The use does not want to use a voltage power source in his version of the circuit.
He is using the diode as a photo voltage source which drives R3, so the original circuit voltage has been replaced by a shorting link.
E
