Price is coming down: US$58.99
https://www.ebay.ca/itm/144114580754
Edit: oops! I hadn't noticed the shipping charges.
What is inside the rotary switch?Oh I did take a picture but did not send it. I have the interface board in a box.
I can do that. I think what will happen is that only every other click will work. I am also a little concerned if the board can handle the constant load. In the original encoder there is a pulse and then it goes to zero (no load). In the new encoder every other click will have a load on it ( as far as I can tell ). I wouldn't be happy if my new hobby blows up the drierHave you connected the new encoder to see if it works as is?
If not, than an inverter gate on each output may do the trick.
The encoder I showed AEC16BR1E - well it was until I removed itWhat is inside the rotary switch?
