Laird Scooby
- Joined May 31, 2011
- 11
I'm not sure you're missing anything to be fair. More likely i'm missing something! Don't know if you saw my thread introducing myself but i pointed out i'm a bit on the rusty side of things - like about 27 years rusty!Hi,
Again I mean this in good intentions,
Am I missing something then,
The R27 is in series with the base of Q10, it drops the voltage, and thus the current
by [(VCC - Vbe) / (R27+R34)]. Not including HFE parameter which would raise the input impedance higher.
This is with collector opened.
The 2 diodes keeps a good base bias voltage on Q10 to help put the amp into Class AB mode.
Needs to have some base current to keep from cross over distortion.
For fun I breadboarded the circuit last night using different resistor values to design it for an output current of 1mA, with no load, and got a 16vP-P with no crossover distortion.
However, without digging through to find my course notes (which i've got a horrible feeling disappeared somewhere) i would have said the output is Class B - i could be wrong on this of course but i agree that you need to bias the transistor on to reduce crossover distortion. Also i was always taught to look for the worst case scenario, in which case you'd have 24V trying to get through a single 15Ω resistor, hence my power calculations. The fact that the resistor is frying suggests the worst case scenario in his circuit exists. If his power supply is one of the kind that self regulates the current O/P then it could be it's momentarily shutting down as it's delivering in excess of 1.5A, hence the fluctuation he describes.
I'm sort of guessing here that if he soldered everything on stripboard, he's either not made a cut where he should have done or got a minute blob of solder linking 2 tracks or something along those lines. It could also be that he's not got the correct value resistors in somewhere.
I wasn't questioning if the circuit worked as per the design shown, more the fact that he may have altered the design as in the very first post it's a little ambiguous whether the circuit shown is the original or the one he modified.
