Hello all, this is my first post I hope I'm in the right place. I am building a diy spot welder and found a very basic high current inverter circuit and would like to know if my modifications would work. The design explanation can be found here
The schematic is attached. I would swap the mosfets for IRFB3256PBF and connect the gates to pwm outputs from an rpi pwm board, and swap the momentary switch in the circuit for a standard 2 position switch like on the back of a pc power supply.
This should give me the ability to make the spot welder dual pulse through some simple code. That part it's easy for me, just need some information on the circuit design as I love tinkering but I'm no engineer. Thanks in advance!
