Circuit for measuring voltage and current during discharge of a battery
john___
Joined May 26, 2019
Hello dear community,
I hope I landed in the right category but I have an important question for you specialists.
I would like to build a circuit for measuring voltage and current during discharge (with different load resistances) of a battery. Of course I've already thought about that, but I'm not sure yet how to build the circuit.
Can you give me some tips please?
Thank you in advance for your help!
John
MrSoftware
Joined Oct 29, 2013
2,280
Are you going to manually record the values, or do you want the values logged automatically over time? Before you start designing a circuit, you first need to list your requirements in detail.
john___
Joined May 26, 2019
Okay, I already have two digital multimeters that I can connect to the PC to log the values.
john___
Joined May 26, 2019
Than why not use those to measure the battery voltage and current?
Thank you for your reply. Basically, I know that voltage is always measured in parallel and current in series. Unfortunately, I need a bit of help creating the circuit diagram (also in the context of the load resistors - there I would use 10, 100, 1000 ohms)
38,913
You measure the voltage directly across the battery.
You measure the current by putting the multimeter current terminals in series with the battery load.
Reloadron
Joined Jan 15, 2015
7,976
OK your circuit could look a little like this one;
The voltmeter is across your supply, a battery. Your current meter is in the current path to the load and finally you have three switchable loads. The load switch is a simple three pole switch like a wafer switch. Voltage and current will determine the actual switching. If you want data logging it depends on the data logging functions of the meters you have. That what you want? There is a number of ways to go about it,
Ron
dendad
Joined Feb 20, 2016
4,642
You may have to check the meter internal connections if you were to data log to a PC. There is a chance of a short if the PC interface in the meters are not isolated. An optical isolator may need to be added to the circuit, or a radio link.
dendad
Joined Feb 20, 2016
4,642
Another way to do it is to run a constant current load and log the voltage.
Years ago, a guy I knew had a simple battery test. It had an under-voltage sensor that switched off a clock. So, he set the clock to 12, and started the discharge. The clock ran until the end voltage and that disconnected the battery. The time the battery could run for was read off the clock.
