Circuit for flashers using PWM
Linus Jönsson
Joined Feb 18, 2019
Hi, currently working on a simple circuit to turn on/off flashers on a car using a solid-state relay and PWM from a mcu. Can anyone verify my circuit diagram, not sure how to use the solid-state relay yet.
See attached screenshot:
shortbus
Joined Sep 30, 2009
10,050
No need to dim, but want to flash them 90 +- 30 times/min
To do that won't you need to bypass the existing flasher module? Don't know about the cars with a BCM, but the old ones only had one flasher that was then controlled by the turn signal switch, both turning the flasher on and directing it left or right. Today's cars, I think, have the flasher in the BCM(body control module).
