I'm modifying the turn and brake lights for an older car using a two-element 1157 bulb. The smaller filament in the 1157 bulb is used exclusively for park/running lights; the larger filament is "shared" by the turn signal and the brake signal. In the original old turn signaling switch when a turn is called for and actuated the switch would simultaneously open the brake circuit for that side allowing that large filament (even with brake "on') to flash while the other side would have solid brake light when brakes were applied. My dilemma is the new modern steering column and turn signal circuitry provides TWO separate operating fused circuit wires ( Turn and brake ) going to that one remaining element.
I would like to develop a circuit that will sense a turn signal and at that time open the brake circuit to allow uninterrupted flashing as long as turn signal is on. Once turn signal comes off normal brake light function can resume.
The large element pulls 1.3 Amps.
My only thought on this is to use a NC relay along the brake circuit governed by the turn signal along with a capacitor that would keep the relay energized just slightly longer than the length of the flash ( 1/2 second ?) . Once flashing was no longer active the relay would revert to NC and would allow the brake light to come on when brake was applied.
I would think I would need two of these devices one for each 1157 tail light bulb.
The only place I have to mount these would be near tailight behind bumper/rear fender as there is no room under the hood or in the cabin. They need to be sealed for the elements so maybe solid state relay ?
I'm going to try and research what type and size capacitor to use but I'm sure this issue requires more experience in designing it than the zero I have.
Any guidance will be greatly appreciated
