The circuit fragment shown, along with the amplifier power connections, is an incomplete example of how to bias an amplifier to provide an undistorted output when operated in a single supply mode. The text should have explained that. It is very important to read and understand the text,not just look at the pictures.Pls explain with this diagram
OThe circuit fragment shown, along with the amplifier power connections, is an incomplete example of how to bias an amplifier to provide an undistorted output when operated in a single supply mode. The text should have explained that. It is very important to read and understand the text,not just look at the pictures.
There is no negative feedback to reduce the circuit gain below the device's open-loop gain. The device is operating as a comparator, not a linear amplifier.The circuit fragment shown, along with the amplifier power connections, is an incomplete example of how to bias an amplifier to provide an undistorted output when operated in a single supply mode.
It is an incomplete circuit fragment in an inadequate textbook.There is no negative feedback to reduce the circuit gain below the device's open-loop gain. The deevice is operating as a comparator, not a linear amplifier.
The order of magnitude (10 ohms vs 10k) determines current. Current matters in circuits.I understand the circuit operation but I find it difficult as how they arrive at those resistors values. Can't we use 10ohms instead of 10k ohms for example in biasing the non inverting pin using voltage divider?
Logic D | Homework Help | 53 | |
| S | Circuit design for battery backup | General Electronics Chat | 10 | |
Pre-Amp Circuit Design For Piezo-Electric Disk | Analog & Mixed-Signal Design | 17 | |
| T | analog IC design in the submicron technology (12nm<L<180nm) | IC Design | 0 | |
| V | IR2111 Circuit design for Half bridge control ..#2 | General Electronics Chat | 3 |
