Shouldn't that be "225mA"?...if the load draws more than 10 ma
I've worked it out on my whiteboard - Definately doableActually the problem cannot be solved using only the given components. A voltage greater than 3.3V is required.
Bob
Oh whoops - Well I got the answer that they'd probably give full marks for...I agree with Bob. Check the datasheet for the LM358.
This looks like another example of a poorly-set question.
Probably true.Oh whoops - Well I got the answer that they'd probably give full marks for...
