Circuit design MOSFET
ridyzz
Joined Sep 24, 2021
7
I got a circuit and do not know the exact application of it. I would highly appreciate if you guys might help me with this.
Thanks a lot.
BobTPH
Joined Jun 5, 2013
11,524
No, you don’t have a circuit, you have a question asking you to design one.
The application is a power supply current limiter, but I doubt that iis what you are really asking
Since this appears to be homework, what have you done si far, or where are you stuck?
Bob
DickCappels
Joined Aug 21, 2008
10,661
It looks pretty straight forward to me. Use the components in the blue box along with the circuit shown to measure current and shut off the voltage to the load if the load draws more than 10 ma.
Hint: I think this problem presents a bad example using an opamp as a comparator.
A question for you: What would the MOSFET be used for?
BobTPH
Joined Jun 5, 2013
11,524
Actually the problem cannot be solved using only the given components. A voltage greater than 3.3V is required.
Bob
bertus
Joined Apr 5, 2008
22,928
The LM358 seems to work from 3 to 32 Volts single supply:
The problem however is that the low can be near the 0 Volts, but the high is not at the supply voltage.
BobTPH
Joined Jun 5, 2013
11,524
Actually, if you read the question to mean that it is on at 10mA and off at 225mA with no specification for currents in between, and you get a typical part for the MOSFET, there is a solution that does not use the opamp!
Bob
DickCappels
Joined Aug 21, 2008
10,661
@click_here , you are right, it is 225 ma to shut it off. (When I went back to get the detail of the over-current condition I read the wrong number).
I think some of us have predefined concepts that are keeping some from seeing how this can be done. Let's let @ridyzz work it out without our idea of the "right way" getting in their way of finding the answer.
