Circuit Analysis - Am I missing something?
jethro99
Joined Oct 31, 2020
66
Simple circuit. Lithium battery as 12 volt power supply. Approximately 1 amp electrical load. Circuit distance is 30 feet round trip. Manufacturer specifies a 3 amps fuse at the battery.
A wire size selection chart I have indicates 16 gauge wire to be adequate for X voltage drop. 12 gauge wire for Y voltage drop.
My silly question is, is there ever any concern with using a larger wire than whatever size is specified in the chart? I am guessing no. But some keyboard cowboys are taking a contrarian position.
Maybe I am not seeing the forest for the trees.
WBahn
Joined Mar 31, 2012
33,187
The key phrase is "is there ever any concern". Larger wires are heavier, cost more, conduct more heat, and take up more space. If your application is sensitive to any of those things (and probably some others), then there can be a concern.
But if you are restricting the discussion to only the electrical considerations, then there should almost never be any concern (I only say "almost" because there are always lunatic fringe applications in which the detailed characteristics of seemingly innocuous parts are important).
