Choke coil power factor and inductance
Yashiro Isana 1
Joined Apr 12, 2017
12
Greetings,
I would like some help on this.
Since, Power Factor= True Power/Apparent power
What will be the Apparent power?
And For Inductance(Inductance= L*di/dt), what will the L and dt(cross sectional area) be?
WBahn
Joined Mar 31, 2012
33,135
Are you going to make ANY attempt at working ANY of the problems you are posting?
If you can't even make an attempt to find the apparent power from the information given, then you need to drop this course and retake it, making sure to actually pay attention next time.
38,764
You have the current and power. From that you can calculate the resistance of the coil.
You have the voltage and current. From that you can calculate the apparent power and coil impedance.
From that you can calculate the power factor.
Knowing the coil resistance and the coil impedance you can calculate the coil inductance.
If you can't do those calculations then, as WBahn stated, you should retake the course. :rolleyes:
