Greetings all ! I am new around here and in desperation on line I found your forum .I was given a Chinese-made 7 Star auto transformer which went down a few months ago. I opened same and found the sliding switch at the top damaged . I tested for continuity and am getting a reading with the two ends of the coil on the input side and that single end on the output. When I bridge the socket pockets of the switch I get no reading.The fuse is OK. Does anyone have a Schematic for this type of transformer or could someone shed some light on what I may be missing .Because of switch damage I am planning to run it straight 220/110 [step-down for which it was used] Thanks for any input and be Blessed.
