Delta is a cool system for high speed pick and place on conveyor belts, but its a poor choice for 3 axis CNC machine. A linear XYZ give much better accuracy especially when real world objects benefit from having straight lines, and better still when those straight lines correspond directly with an XYZ axis.
Thats what I was thinking also, with that much speed, you would have to heat up the plastic pretty fast for the extruder to keep up with the motion, but then it could take time to cool down, and could cause warping, etc....
I think to simplify things, I will just make an extruder attachment for my CNC PCB mill/Drill, and see if I can do some Plastic 3D printing with it.... the Z axis travels up to 6" high and the bed is 12"(X)16"(Y), so I should not have any issue doing big pieces..... just need to make a new bed for it to "warm" the print to keep it from cooling too fast and warping, and an extruder to print with...
