I know. There is still much more AC component in them than a linear. Check out the specs on them. Some claim a 30mV PP ripple! And that's what they claim too. Closer to the truth it could be 50mV !!!The idea is they are the raw power. The regulator comes after, and switching power, while noisy, is also very regulated.
Balderdash!These supplies are arguably unsafe for an experimental supply powering circuit boards on your desk, because they're not isolated.
You can hear 100kHz switching? My, what good ears you have.The power isn't as clean either. Not suitable for audio, and after all this will be a dual rail supply.
I hold an 90% pass grade with DC power supplies that I studied back in 98.Balderdash!
They most certainly are isolated.
Just because you don't understand the technology is no reason to bad-mouth
You have "Cal Trimpot" as a 200 Ohm pot. Not good. If you accidentally set the 200 Ohm pot too low, you would burn it up, as the LM317 will source up to ~2.2A short term attempting to keep Vref (OUT to ADJ) at a nominal 1.25V; ±50mV.Yeah this is correct. Sometimes I blow it up a bit to make sure I am not going blind.
I do this so the pot can be adjusted to the scale on the artwork as a "once off" thing on the board. It is a trimpot which I don't have in my Circuit Maker 2000.You have "Cal Trimpot" as a 200 Ohm pot. Not good. If you accidentally set the 200 Ohm pot too low, you would burn it up, as the LM317 will source up to ~2.2A short term attempting to keep Vref (OUT to ADJ) at a nominal 1.25V; ±50mV.
If you go "by the book", it should be a 120 Ohm fixed resistor; or Vref*100 (it can be lower if necessary, but the idle current subtracts from max output). Using 120 Ohms or Vref*100 guarantees a 10mA output current which is required for guaranteed regulation. If you can otherwise guarantee that there will be at least 10mA output current, you can increase the value up to perhaps 330 Ohms; after which the Iadj (50uA-80uA) error term becomes more significant.
Done.Just an appearance issue in the schematic; I generally put the 100nF/0.1uF cap just to the right of the R1/R2 divider to suggest it needs to be very close to the regulator on the board; and on the board, keep it close to OUT and GND, and the leads short.
Using a 1uF cap from ADJ to GND will help eliminate the overshoot that occurs during startup, and will also help a great deal to reject transients. If you use a cap here, add a diode from ADJ to OUT if Vin > 20v.
A 10uF cap on the output will "buy more time" for the regulator to deal with transients; the LM317 is somewhat slow to respond. 1uF is kind of minimal.
No way. It won't be responsive unless the load is actually something enough to discharge it quick.Might want to consider increasing the cap on the output to around 100uF for load transients.
I sometimes do 100 drafts before I am happy.Now take those images and start a completed project thread. It is nice to see it done correctly now and again.
The simple, but safe and sane power supply has been submitted.Now take those images and start a completed project thread. It is nice to see it done correctly now and again.
All modern Cel phones use Class D amps for audio, even for the headphone/music jack and speakerphone. They sound quite good and can be very loud, especially the alarms ringtones. Relative to the meek "beep beep" of cel phones circa 2002.Balderdash!
You should look up Class D audio amplifiers. They are essentially forward converters using feedback modulated with audio that has been PWM'ed at a high frequency. Unlike class A and class AB amplifiers, they are very efficient, and dissipate relatively little power in the amplifier itself.
