Cheap TEMU Battery Operated charger using 36VDC USB-C charging port?
Dataman
Joined Oct 2, 2018
28
I am looking for a 36VDC 3Amp charger for a Battery operated Juicer that my Spouse/Wife bought on TEMU.
The seller (and TEMU) seem to ignore request for clarification.
The on-line eManual is nothing but a brochure and states :"Convenient Recharging using the USB-C Charging Port".
Even their reviews seem to be fake (because I cannot believe anyone has gotten this juicer to charge with even a 3.3Amp USB-C Charger.
Here is the juicer:
https://www.temu.com/goods_snapshot..._1738553534129_lzlkdb5dee&refer_page_sn=10032
I found an on-line reference on the Federal Trade Commission Complaints site where they list the Battery as 32-36VDC 6.5Ahr Battery pack. That means a 5VDC 3.2Amp Cell Phone (USB-C) charger will not work at all. Which also explains why after a whole week of charging the juicer still will not work.
Can anyone here point me in the direction of a 36VDC 6.9Ahr Wall Wart USB-A charger that I can plug a USB-A to USB-C Charging cable into to see if I can get this piece of (ooops can not say that here - sorry) to charge?
Jon Chandler
Joined Jun 12, 2008
1,659
You may need a USB C PD (Power Delivery) charger. A 60 watt (to one USB connector) supplies 20 volts at 3 amps (with proper USB C PD negotiation). A 140 watt USB C PD charger can supply 28 volts at 5 amps using a heavy duty cable.
IF the blender is expecting a USB C PD charger, connecting a non USB C PD power supply of anything greater than 5 volts will release the magic smoke.
BobTPH
Joined Jun 5, 2013
11,678
I do not believe that juicer uses a 36V battery, it is probably actually 3.6V, which is a single Li ion cell. The specs indicate an 18650 cell. You could not get 10 of them + a motor in that device. It should charge off any USB port. If it does not, it is probably defective.
Jon Chandler
Joined Jun 12, 2008
1,659
Ahhhh. Did you try to change it with a USB C charger using a USB-C –:USB-C cable? Many devices using a USB-C connector for 5-volt-only operation leave out the required resistors on the CC lines of the USB-C connector. USB-C PD supplies WILL NOT supply any voltage without these resistors.
Try a USB-C to USB-A cable to a USB charger with a USB-A connector. I'll bet it will work.
Sorry, I can't decide if I like "USB-C-PD" with hyphens or "USB C PD" without, so I seem to alternate.
