Cheap dual Voltage Power Supply
SamR
Joined Mar 19, 2019
5,540
Just came in today and only took a few minutes to build. AC rectifier, LM317 & LM337 adjustable regulators, and filter/smoothing caps. No transformer but I am powering it with a 28-0-28 Triad VPL28-2000 transformer. Adjusts to well over +/-20VDC and with this XFMR has plenty of power. All of the resistors and caps were well within spec for a change. Not too bad for a $7 kit.
The smoothing caps that came are 2200uF Nichicons with 0 ESR.
upand_at_them
Joined May 15, 2010
939
Hi SamR. Do you have a link to the dual kit? The regulator heatsink pads look like rubber sheets instead of mica...not sure how much heat will transfer with rubber.
