Depends on your goal. For most purposes, the electrode should be negative so that most of the heat goes into the metal. For light gauge stuff, the electrode should be positive, so that most of the heat is in the electrode.When you DC, which polarity does the rod go on?
Gee... If there was only some way to know where profbuxton was located on this planet of ours.#12, I have a couple of 240V fan trays with six fans on each. How much is postage???![]()
At 10% duty cycle, that's only 7.8 cents per hour.you will probably see a ~ 5 - 6+KVA input for ~ 2.5 - 3 KW output.![]()
So it's low efficiency. Another form of low efficiency is having a welder and not being able to use it because I don't know how.Operating cost isn't the issue. It's the knowing how much power you're putting in for what little you get out that's the kicker.![]()
I just tried 80 amps of AC and all I did was vaporize 6 inches of 1/8th rod and leave a few spatters of metal on top of the 1/2" steel plate...but thanks. You are the first person to recommend any settings for beginners. I'm surprised at how fast the welding rod disappears. I have a hunch that I could make a whole inch of weld with a 1/8th rod. Whadda ya think? What should I expect for a length of bead from one rod? I also have some 3/16th rods. I think I should go to a welding shop and watch for a while because I have no idea what to expect...how long to dwell on a single spot, what to expect out of a welding rod, whether it's easier to try to make a puddle in a corner or what a simple line is supposed to look like when it's finished. Maybe Youtube is the place to go.For beginner work and getting the feel I would start at ~ 100 amps with that size of rod
Exactly what I was thinking too... good luck!Maybe Youtube is the place to go.
The batteries have no access door to replace them. You would have to disassemble the whole module to access the batteries.Look Ma, no batteries!
Don't even think of trying to weld without a proper helmet. Also, cover all of your skin with natural fabric (cotton, leather) clothing. An arc burn (a sunburn caused by an electric arc) is 10X as bad as the worst sunburn of your life. It is like sunbathing on Mercury.Hmmm...maybe the goggles that came with my oxy-acetylene kit...
