I have a series string of super caps made by Amperics. They are individually 80 fard 14 v ,5 in series.
They call it a 400 fard unit. I hooked them up to a 12 AGM battery with a full charge of 12.9 volts.
The caps were empty. It took about 20 minutes and the caps went to 12.6 v. Is it normal for there to be a slight
difference in voltage. I use my mini jumper cables made with 10 ga wire. Now I need to discharge them so I can handle them in a project. How would you discharge these? They are rated at 250 A.
