Hello All
Pls advice me, i have 2 wind generators one is 12v ( 1000watt) 2nd is 24v (1000watt), when i buy these its specification i got on paper
i tested these on with car engine starting, at car engine starts, and engine running at idle speed 1000rpm, and same both generators running at 1000 rpm speed,
what is shock for me is , 12v generator output 60v dc, and 24v generator output 132 vdc without putting load on it, i want use my batteries to charge, and afraid to plug batteries wire due see high volt, pls advice, if i plug batteries wire, is it make battery demage ? or i need to use some device for mange volt, from 60vdc to 12vdc ?
waiting your earliest reply
