Charging a battery with solar, while using it
Michael.R
Joined Jun 28, 2019
Hi all, I'm a bit new to electronics but I want to make a project and need your help.
I want to power a pump using a battery.
The battery need to get recharged every time the solar panel can supply the needed current but in the same time still supply the needed power to the pump.
I suppose I need some kind of a charging regulator board for this?
Also, do I connect the Solar panel in series to the battery and the pump or there are parallel connections needed?
The specifications of all parts are:
Solar panel:
20W, 5V, 1.2A (All rated for max output, after the regulator)
Pump:
3.5-9V, 1-3W
how would you make this? and what battery would you use?
oz93666
Joined Sep 7, 2010
742
So the solar panel outputs 5V when delivering max power , that's about 7 V open circuit (No load) ...
You would not need a very big battery , and no regulator is needed if you have a battery protection circuit ...
The voltages for the panel and the pump don't match very well ... lithium is the best choice for battery and you may get away with 1 cell .... that's a voltage between about 4.2 and 3.6 ... the pump will be a bit under powered , but will work ...
You just need two components ... the battery ...
just one of these is enough ... get a recognised brand panasonic ..6 pounds UK it will hold 10WHrs enough to run the pump 10 hrs (at 4V) https://www.ebay.co.uk/itm/3400mAh-...hash=item3b30608f3d:m:mW6lttqfQ7vbdhaCtnaVZCg
and a protection circuit ..... many different types .... very cheap
this will connect panel with battery and prevent overcharging , and the pump is connected to the battery
https://www.ebay.co.uk/itm/1S-5A-3-...985889?hash=item23b0dad1a1:g:4sIAAOSwvmNbKJ21
