Charge pump for solar cell.
RobertsMrtn
Joined Jul 19, 2020
I have a 7V solar panel which can power an electric pump to pump water to a height of 30cm when the sun is not behind a cloud. When the sun goes behind a cloud, the power drops too low to power the pump fully. Is there a circuit I can buy which will charge a hefty capacitor and then intermittently discharge once the correct voltage has been reached so that the pump will still pump water intermittently when the sun goes behind a cloud? I have looked at charge pump circuits which seem to do this type of thing, but can I wire my own capacitors to achieve different output voltages and discharge times? I also need to be able to disable the circuit when the panel is in full sun.
ci139
Joined Jul 11, 2016
2,004
The spiral pump
it does look "good" -- only there're 2 things :
  • i must somehow compute the efficiency of such setup ...
    ... to be able to compare with the other ones ( there is an extra flow-drag because of the extensive tubing length ... )
  • it generates high atmosphere mixed water content ...
    ... depending on circumstances -- it may favor the algae growth inside the tubing -- so permanent attachment of the tube -- may turn out to be not a practical solution
sparky 1
Joined Nov 3, 2018
1,218
The concept not the materials or a specific replication. Motor should be more compatable to the application such as a low BEMF like a window motor . Improvement using bearings. Photovoltaics directly converted to spiral disk torque on a cloudy day could rely on elevated storage of water lifted during solar intensive times. The use of vortex drain to generate so net loss is near zero.
The use of marsh variety plants that process waste. The real balance being that two systems of pH are needed. Whereas doggy world needs to sell disposable cartridges.
The fresh water is lifted up into two separate systems having water plants.
The alkaline in one and the acid variety in the other. This is why off the shelf is difficult to adapt to a biological system.
ci139
Joined Jul 11, 2016
2,004
made a quick test with tiny 3x 2.4 x 13.6 cm = 97.92 cm² , 6V 60mA solar panel ::
\( \begin{array}{ccccl}
{V_{R=∞}V}&{V_R\\V}&{I\\ \mathbf{mA}}&{R-Rm\\Ω}&condition\\
5.73 & 5.60 & 12.1 & 390 & clear\\
5.70 & 5.47 & 23.8 & 200 & clear\\
5.67 & 5.26 & 43.2 & 100 & clear\\
4.32 & 1.665 & 13.7 &100 & cloudy\\
4.32 & 1.355 & 11.35 &100 & *emulated\ 230W\ light\ source\ apx. at 30cm\\
4.33 & 2.13 & 9.4 & 200 & SAP*\\
4.33 & 3.0 & 7.0 & 390 & SAP*\\
\end{array} \)
from \( \displaystyle{ε=I\left({r+R}\right)=Ir+U \rightarrow \frac{\mathbf{-\Delta U}}{\Delta I}=\mathbf{r}=\frac{U_{\mathbf{0}}-U_{\mathbf{1}}}{I_1-I_0} ,\ \rightarrow \mathbf{ε}=\frac{\Delta\frac{U}I}{\Delta\frac1I}=\frac{U_1I_0-U_0I_1}{I_0-I_1}} \)
returns */!\ it may give better (lower) r value using R values closer to r ...
ε & r :: 5.73V & 11.0Ω for the sunny/"clear" and 4.81V & 277Ω for the "cloudy"
as the best energy transfer occurs at r=R the potential energy output at R is thus respectively \( \displaystyle{P_{r\&R}=\frac{ {\left({ \frac{ε}2 }\right)}^2}r} \)
sunny P=750mW to LOAD
cloudy P=20.9mW to LOAD
avail energy RATIO P.cloudy/P.sunny ≈ 27.8%
EDIT :: i thought i passed a mistake - and i did it's 2.78% , roughly \(\frac1{36}\)
