Changing voltage with a changing frequency
Deleted member 115935
Joined Dec 31, 1969
0
as others have said, yes
but it would be good to know what sort of frequency range and voltage range in you need.
After all, frequency to voltage is what an FM radio does,
( ok the change in frequency gives the change in voltage ) ,,,
Alternatively, hard limiting a sine wave of variable frequency to a square wave, and then low pass filtering the output will give you a varying output voltage as the input frequency changes.
E_enthusiast
Joined Aug 20, 2020
31
Well if you could help me it would be awesome, the lowest frequency can be as low as 5 hertz... And the highest frequency can be 5kHz.. and the voltage varies from 0 to 5 volt.. do you think it is possible? Because as far as I know it's practically impossible
OBW0549
Joined Mar 2, 2015
3,565
By itself, that won't give you a frequency-dependent output voltage. But if you take the square wave and use it to trigger a monostable multivibrator, and then low-pass filter the multivibrator's output, that would do the trick.
EDIT: Lots of frequency to voltage converter circuits, here.
Joined Dec 31, 1969
0
OOPs ,
your right, put it down to snr moment,
yep dont just hard limit and get the DC !!!
