Hi AAC
I am new to electronics, newly retired physician, studying electronics and repair, have a 24v, 15a SMPS, trying to lower the voltage to 12v, it is based on push pull have-bridge topography and TL494, what I did was de-solder the transformer (inner layer the primary, then 2 layers of 4-copper wire secondary forming center tapped 13 turns, then thin 13 turn double direction wire going to the thermal protection circuit, then outermost 21 turn auxiliary winding).
I shortened the secondary wires to 6 turns, and reassembled.
I am now getting 22 volts at the secondary and rectifier diode, and hence in the output, voltage at pin 1 of the TTL464(+error amplifier) and pin 3(FB) are both 2.5, tried changing the voltage divider network going to pin 1 but same voltage I get, some help will be much appreciated
