Is there any kind of IC/ circuit that can output a changing voltage proportional to a changing input frequency?
Thanks I will check it outYes. It's called a Frequency to Voltage converter.
SG
Thanks, it helped a lot.hi,
This is one example.
E
Thanks for the help, appreciated.Check out the LM2907/LM2917 and see if it'll do what you need.
Thank you, the lm331 has caught my interestF to V and V to F as mentioned. You can either roll your own or buy a plug and play turn key solution depending on your application(s).
Ron
Thanks, that helped a lot.Yes. It's called a Frequency to Voltage converter and they are generally also Voltage to Frequency converters.
SG
Well if you could help me it would be awesome, the lowest frequency can be as low as 5 hertz... And the highest frequency can be 5kHz.. and the voltage varies from 0 to 5 volt.. do you think it is possible? Because as far as I know it's practically impossibleas others have said, yes
but it would be good to know what sort of frequency range and voltage range in you need.
After all, frequency to voltage is what an FM radio does,
( ok the change in frequency gives the change in voltage ) ,,,
Alternatively, hard limiting a sine wave of variable frequency to a square wave, and then low pass filtering the output will give you a varying output voltage as the input frequency changes.
By itself, that won't give you a frequency-dependent output voltage. But if you take the square wave and use it to trigger a monostable multivibrator, and then low-pass filter the multivibrator's output, that would do the trick.Alternatively, hard limiting a sine wave of variable frequency to a square wave, and then low pass filtering the output will give you a varying output voltage as the input frequency changes.
I doubt you'd find anything to cover a 1000:1 ratio in a single range accurately. You'll likely need several switched ranges.the lowest frequency can be as low as 5 hertz... And the highest frequency can be 5kHz
EDIT: Lots of frequency to voltage converter circuits, here.
by Aaron Carman
by Robert Keim
by Aaron Carman
by Aaron Carman
