Dear All;
I have a problem about a ceramic capacitor in my design.
The problem occurs at C6. Note : C2 and C5 is same capacitor but no error occurs at them.
C6 is 1uF, 50VDC, X5R, 0603 MLCC type capacitor (Mfg P/N : Samsung CL10A105KB8NNNC)
Let me define the board and problem.
- This design is low-power RGB LED driver which has LED Driver IC and LDO.
- Design can work at 19~28VDC nom. at 24VDC (VIN power port)
- Design has resettable fuse and TVS diode(SMAJ26A) on LDO power input.
- LDO just fed LED driver IC, not LEDs, LEDs anodes are directly connected to 24VDC, LEDs cathode are connected to LED Driver IC.
- This sheet is called as a one pixel of linear luminarie. One luminarie has 8 pixels(8 pcs of given sheet).
- My power supply can fed up to 30 meters of linear luminarie and it means 240 pcs of pixels.(One pixel is given sheet as specified)
Please note that, 240 pcs of given design is connected as parallel to one power supply.
- 24VDC / GND distributed parallel with help of extra cabling . Data signals (SDI / SDO) are serially connected to each pixels, as in and out fashion.
The problem is;
C6 capacitor blows at a random time and at a random pixel, C6 become short-circuit.
So, LDO stops functioning, F4 fuse protects C6 to fire up. Then, remaining portion of cascaded connected pixels can't work, because data can't go through this defective pixel.
When we remove C6 from blown pixel, system / all pixels resumes to functioning.
Somehow, this capacitor blows and short-circuited, so it malfunctions of this pixel line.
What we try (All our changes and attempts doesn't give any result). Given attempts are done step-by-step and make observations for sufficient time.
- We decrease the power of pixels to reduce total current flowing through VIN line.
- We decrease the voltage of power supply to 21VDC.
- We place bulk capacitors (680uF, 100VDC, Aluminium Electrolytic) at VIN line to reduce overshoots and possible spikes at start, 10th, 20th, 30th meters of pixel line.
- We made observation that issue is happening at power on : Absolutely NOT. Cap may take the knock at power-on, but we oftenly observe total malfunctioning of pixel while system is working.
- We get measurements from start and end of power line(VIN/24VDC) of luminaries with scope. Power seems very very clear at power-on, continous and power-off times, no overshoot/no spikes, voltage rise to 24VDC very soft (5ms)
As seen here, we do most of known modifications and observations.
Pleased your help about what can be the reason of specified blowing cap issue.
Best Regards,
The problem is;
Best Regards,
