I'm working on a physics project for which I have to charge a 1.0 F capacitor "as completely as possible" by dropping a magnet through a solenoid coil. I have tried this with a voltmeter in place of the capacitor and found that the graph of induced voltage vs. time looks something like this.
If I were to hook up the capacitor directly to this voltage source, it would simply charge and then immediately discharge. Obviously, I will need some sort of (preferably full-wave) rectifier. Since I'm dealing with pretty small voltages (about 6.3 V max), minimizing the forward voltage drop across the rectifier is going to be key. I was reading here about center-tapped rectifiers, but I know very little about different sorts of transformers. So, my questions for you all:
1. Would a center-tapped rectifier be an appropriate solution, given the small input voltage I'll be working with?
2. If so, what properties should I be looking for in a center-tapped transformer?
3. What's to stop me from using a step-up transformer in order to increase the voltage from the primary to the secondary coils? Wouldn't this cause the capacitor to charge faster/more completely?
4. Is there an advantage to my using a diode bridge over a center-tapped rectifier?
Thanks very much!
xenolalia
Thanks very much!
xenolalia
