Center tap microwave transformer.
Hutch2793
Joined Jul 7, 2020
133
What is the voltage regulation requirement? Is pulsating current okay?
The scope showed you a lot of information that isn't useful, e.g. RMS, peak to peak, and average voltage, and cycle, PW, and duty. You can measure or calculate the important things.
Don't get lulled in to using bogus information presented to 3 decimal places.
Clipped image:
Voltage requirement is 7 volts. I believe pulsing current is ok, but I wouldn’t mind smoothing it to learn how it’s done. For the testing I’m doing Pulsing current is ok.
dl324
Joined Mar 30, 2015
18,473
You could use a power zener diode to reduce the peak to 7V.
You have enough head room to use a 7V regulator. An LM317 with an external power transistor would let you adjust the voltage. The datasheet will give an example with an external pass transistor.
Hutch2793
Joined Jul 7, 2020
133
I would use a capacitor to smooth and then a zener diode? What is the numbers on that. I had a peak of 11-12 volts I believe, so how much does the voltage drop from a zener?
“You have enough head room to use a 7V regulator. An LM317 with an external power transistor would let you adjust the voltage. The datasheet will give an example with an external pass transistor.”
I actually have lm317’s could I use a transistor and a potentiometer for variable voltage? how do you figure out the transistors needed?
sorry for all the questions, but I haven’t had any actual schooling on electrical engineering. I’m in calculus and physics now.
dl324
Joined Mar 30, 2015
18,473
You can use a variation of this circuit:
The voltage is determined by R4 and R5.
\( V_{out} = 1.25V(1+\frac{R5}{R4}) \)
You need a power transistor that can handle the current and power dissipation.
LM195 is an integrated power transistor. You can't do that (parallel them without ballast resistors) with regular power transistors.
You can replace the NPN power transistors with a power PNP:
If you want to control the current ratio in the regulator and pass transistor, you can do this:
(National Semiconductor Voltage Regulator Handbook)
If you put the regulator and transistor on the same heatsink, the regulator can protect the power transistor.
Hutch2793
Joined Jul 7, 2020
133
All of these components are 3 amp max though. My transformer runs over 3 amps and I need it too. 3 amps is the minimum.
dl324
Joined Mar 30, 2015
18,473
I was typing in the exact part numbers you listed on the circuit though.
Which one? I posted 3.
The first was using a device that seems to be hard to find (LM195/395). The second shows the classical PNP external pass transistor. If you want to use an NPN, you can use a variation of the first circuit. The third circuit shows how to specify a specific current sharing between the regulator and pass transistor.
Hutch2793
Joined Jul 7, 2020
133
Actually I just realized I save the wrong schematic and bought parts for a regulator circuit from a past thread.
dl324
Joined Mar 30, 2015
18,473
I have looked for the parts you have listed and they are tough to find. Sorry, I have been pretty busy.
You don't need to use the transistors in the circuit diagrams. Just pick something appropriate for the current, voltage, and power dissipation.
For an NPN power transistor, 2N3055 is commonly used. It's PNP complement is MJ2955.
AFAIK, NPN power transistors still cost less than PNP, so the two transistor combination in the first circuit is used.
Which circuit are you planning to implement?
Hutch2793
Joined Jul 7, 2020
133
Probably the 1st, or 2nd. It all comes down to what I already have and can get the easiest. The least complicated method as well.
dl324
Joined Mar 30, 2015
18,473
Personally, I'd go with the 3rd. It lets you specify the current ratio between the regulator and pass transistor. If you mount both on the same heat sink, the built in safe area protection in the regulator can protect the pass transistor.
To use an NPN transistor instead of PNP, you can use this circuit from a Nat Semi Voltage Regulator Handbook:
Hutch2793
Joined Jul 7, 2020
133
Alright, I will look into getting those components. They will b a little harder to track down and take time for me to understand it.
28,352
We are talking about many different things. I’m trying to keep it all straight, I apologize. You say that it can’t be measure without one and you say it can’t be measured with one? “You can't measure unfiltered pulsating DC with a voltmeter. With a filter cap, you don't know what the meter is measuring because the DC range can't measure quickly varying voltages.” How do I measure then? I need a 7 Vdc voltage regulator and a capacitor, correct? I know I need a fuse, but is there anything else I need?
Actally you can measure the unfiltered DC and usually you will get the peak voltage or close to it. But the number is not very useful. So add a capacitor of several microfarads across the voltage and you will read much closer to the peak voltage. That voltage will drop as you draw current with a load.
There is certainly a big difference between making a measurement and making an ACCURATE measurement.
dl324
Joined Mar 30, 2015
18,473
You don't need to use the transistors shown in the circuits. Just use something appropriate. The PNP transistor in post #94 can be any general purpose PNP (2N3906, 2N2907, BC557, etc).
Hutch2793
Joined Jul 7, 2020
133
I have been doing some testing with two different transformer rewound with 12 gauge wire. I’m thinking about wiring two transformers together, as well as making a regulated supply circuit like you have been helping me with.
I rewound both transformers to supply 13.89 volts(according to that cheap scope) the center tap for both supplies 7.25 ish. I wired up a 22k uf capacitor and a resistor and it was showing a pretty steady dc voltage, but then it started showing negative voltage. Any idea why I’m getting the readings?
