Center Light the lits only when both signal lights are on
bagjanfr
Joined Apr 17, 2024
8
I might need to create a circuit that detects when both the signal lights are on (hazard lights) and then activates the center light on my bike.
Means the center light should be off when only one side is lit.
I there a ready module I can buy, plug and play for this project, or I realy have to make an AND gate.
Aside from AND gate, anything else I can do that produce the same result?
38,842
If the lamp is already lit by another circuit, such as from brakes, then the AND gate in post #4 may need to be a high side version.
28,364
If you want a "plug and play" arrangement to accomplish the same function, use the standard cube style automotive relays, each with the normally open contacts in series to light the center light directly from the supply.
