Hello!
Years ago I built an infinity mirror with a shadowbox and LED strips. It's great! I hang it on the wall or ceiling, depending on my space. I just moved into a new apartment and want to replace a ceiling light with my mirror. I removed the light and wired a short extension cable into the electrical wires of the two-wire ceiling port. Unfortunately, when I plug in my fixture and turn it on, the infinity mirror flashes on then turns off repeatedly. It seems like it is drawing too much current and shutting off, then it tries again in a loop. I see the small light on the power supply flash on and off as well. It is an old building, but surely this thing doesn't draw THAT much power! The previous light fixture was also LED. Some important details and debug that I've done:
Thanks!!
- Power measurement of my fixture: 750 mA at 12V = 9 W
- Power measurement of previous light fixture: 230 mA at 55 V = 12.65 W
- Note that I could not measure the voltage, 55 V is the minimum that the power brick label says.
- So the old light fixture draws MORE power, yet has no problem!
- Sometimes the previous light fixture would strobe before fully turning on.
- My infinity mirror works in other wall outlets in the apartment. Thus, the power supply and LED system are working.
- I have redone the ceiling wiring many times. They are securely connected. I plugged in the old light into my fixture and it works fine.
- No other devices on the circuit are on when I test my infinity mirror.
- If I set the lights to very dim on my mirror, it stays on. Then, I gradually increase the brightness. At peak brightness, the LEDs go back to fluctuating on/off. I thought perhaps there was an initial in-rush of current at power up, so I thought starting at dim and gradually increasing would work.
- A hair dryer also barely turns on when I plug into this ceiling port (makes sense, that's a lot of power)
- The 20A circuit breaker does not trip.
Thanks!!
