Thanks Erichi David,
There is full PDF, its +12meg in size.
Search for ltspice_4_e2.pdf
https://www.google.com/search?q=ltspice_4_e2.pdf&ie=utf-8&oe=utf-8&client=firefox-b
Thats a number links for LTS.
Eric
Eric
Thanks JonyMaybe this video lectures about BJT's
Because you still forget that the BJT is a very nonlinear device. And that the voltage gain is not constant but will change with the input signal exponentially.
Av = Vout/Vin = - (Rc * Is)/Vt * exp^(Vin/Vt) (with CE capacitor across RE ressitor)
And this is why single stage BJT amplifier produces alot of distortion. We get about 1%THD per 1mV at the base (10% for Vin =10mV) .
https://www.researchgate.net/public...C_DISTORTION_IN_LOW_FREQUENCY_POWER_AMPLIFIER
http://www.kevinaylward.co.uk/ee/bipolardesign2/bipolardesign2.xht
You can improve the distortion by adding the emitter resistor (without CE capacitor). But to get "low THD" you need to pick RE >> re.
But it is impossible to get high voltage gain and low THD at low load resistance in such a simple circuit.
As you can see you're expecting too much from this simple circuit. And this is why no one uses this circuit as "low THD" amplifier.
Welcome to the real world, Isat current is not very constant and highly dependent on device temperature additional it also varies a lot from device to device even the same type or batch. This is why exact calculations of a BJT circuits are impossible to make.
But if you whant Isat value the for small signal BJTs, expect it to be in the area of about 10^-14 A ... 10^-15 A .
Or use the LTspice value.
Or you can calculate it. If you know the Vbe1 voltage for a given collector current Ic1 you can solve for Isat:
Isat = Ic1 * exp ( Vbe1/Vt )
Or if you know the what Vbe1 is at some collector current Ic1 , then you can compute Vbex for any other collector current (Icx) without knowing the Isat current:
Vbex = Vbe1 + Vt * ln( Ic1/Icx)
And remember that the Vbe will go up 60mV or down for every upward /down change in Ic by a factor of ten (decade change).
For example if Vbe is 0.62V for Ic = 1mA if now Ic increases to 10mA the Vbe voltage will rise to 0.62V + 60mV = 0.68V.
Or if Ic current drops to 0.1mA the Vbe will also drop to 0.56V.
Good bedtime reading
https://forum.allaboutcircuits.com/blog/fun-with-the-diode-equation.589/#comment-1283
