CE - Full Emitter Resistor Bypass - Computing Capacitor Values
elec_eng_55
Joined May 13, 2018
214
Why didn't you use the LTspice file that I upload in my previous answer? Where I properly set-up the transient analysis
I have done that now and I get the 0.2%. I guess I don't know how to use the Transient thing properly.
I don't understand why the different settings give a different answer.
There is still an offset voltage of ≈ -7mV. If I increase the capacitor value to 1500 uF
then the offset falls to ≈ -2.7mV. This is why I was saying that the CNF formula doesn't
seem to yield a good value.
elec_eng_55
Joined May 13, 2018
214
How you define and measure this offset?
Show me the example.
What I mean is that the vout waveform starts at a voltage less than zero. Like -7 mV or -2.7 mV. It is evident in the transient graph. Perhaps the term "offset" was incorrect.
I thought that the CNF formula was yielding too low a value because a higher value seems to be needed to reduce this "offset" issue.
elec_eng_55
Joined May 13, 2018
214
Hi:
I still have a problem determining the required value of an emitter bypass
capacitor mathematically. See attached schematic. Using LTS, a value of
100uF works nicely but my calculated values are always much smaller,
like 8.85uF.
Any help would be appreciated.
David
elec_eng_55
Joined May 13, 2018
214
Why ?
Why 100μF wotks nicely and 8.85μF don't work for you ?
My point is this. Anyone can plug values in an LTS sim and get
lucky enough to find a good value. 8.85 uF results in a much greater
offset voltage on the output, than say 100uF. There is a way to
determine the right value mathematically. I would like to know
how to use the mathematical approach. So far with all my research,
I have not been able to find the answer.
Jony130
Joined Feb 17, 2009
5,598
I cannot understand why you are so bothered about the very small "pseudo offset" in the first place? Which is not a real offset (DC voltage at the output), but a phase shift caused by a capacitor in a circuit. It's physically impossible to have an "offset voltage" (DC voltage) after the signal passes the capacitor in steady-state.
Also, when you are using this equation C = 1/(2 * pi * Fc *R) to compute the capacitor value you should keep in mind that at this frequency (Fc) the phase shift is equal to 45° degrees.
Where did you try to find this answer? You need some basic circuit theory book for sure.
elec_eng_55
Joined May 13, 2018
214
Hi:
I researched Heathkit course manuals which I have thrown out since they weren't very good.
I have searched the internet but each article leaves out stuff and none of them really cover
a topic completely. At least that is the case with the stuff that I have found. I wouldn't mind
investing in a good textbook if someone can make a recommendation. The best info so far
has been on this site.
David
Audioguru
Joined Dec 20, 2007
11,248
I understood that the base line should always be zero volts. If the CNF formula yielded a larger capacitor value, this offset would be much smaller. Is this offset not a form of distortion?
Yes, the offset is distortion. It is normal for a single common-emitter NPN transistor to squash the positive going peak compared to the normal or extended negative-going peak. The voltage gain of the transistor is reduced when it nears cutoff. It causes even harmonics distortion.
Bordodynov
Joined May 20, 2015
3,431
Hi:
like 8.85uF.
David
In your amplifier there are three capacitors, which are high-pass filters. If you want to equalize the time constants, then
A=1/(1+1/jWC1)/(1+1/jWC2)/(1+1/jWC3) , W=2piFre
This is approximate, since the first RC and the second RC affect the dlug on the other. With a very large BETA transistor, this formula works well.
Let us take the frequency at which the attenuation is 3 dB, i.e. 1/2 ^ 0.5. ==> into one cell 1/2 ^ 1/6.
Abs(1/(1+1/jWCi))=WCi/Sqrt((WCi)^2+1)=1/2^1/6
For calc C3 Ri=RC+RL
Bordodynov
Joined May 20, 2015
3,431
There is another harmful effect due to the presence of a capacitor in the emitter of the transistor. This is the detection effect. This effect leads to a dynamic change in the operating point of the transistor.
elec_eng_55
Joined May 13, 2018
214
Thanks for your replies folks. If anyone out there knows of a good textbook please let me know.
David
