I am currently attempting a LED chaser circuit using a 9V battery, a 555 timer, two CD4017, and a CD4081 (AND gate to link the two 4017s). I simulated the circuit on NI Multisim and it worked fine. I then built the led chaser on a breadboard with one 4017 and it worked fine. But when I added the 4081 and the other 4017, it did not perform as expected.
So, I tried a circuit with only the 4081. I connected the 9V battery positive terminal to pin 14 (VDD) and the negative terminal to pin 7 (GND). I then put a wire from pin 14 to pin 1 to be a input logic "1". Then I put a wire from pin 7 to pin 2 to be a input logic "0". However when I used my multimeter from pin 3 (gate output) to GND, I was getting a reading of a little under 9V when I should be expecting about 0V.
Any tips for where I may be misunderstanding the 4081?
