CD4047 output current gate driver?
eetech00
Joined Jun 8, 2013
4,724
Since the IC is driving MOSFETs the IC current output is not really a concern since MOSFETs are voltage controlled. The more gate voltage, the more current it will pass. Drive the mosfet with the most voltage its gate and the IC can Safely handle.
jpanhalt
Joined Jan 18, 2008
11,087
There are several calculators online for capacitor charge rates. This is one I use: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capchg.html
With some approximations, your RC time constant is about 10 us. One RC constant should turn the mosfet on (i.e., about 2/3 x15 V).
10 us = 100 kHz. However, the mosfet will be in its linear region for a good part of that time and may get warm. Why not use a simple multibvibrator and a purpose-designed driver that makes the complementary outputs? Simple one will output amps for a short time, not milliamps.
rsjsouza
Joined Apr 21, 2014
430
@jpanhalt shows a good way to calculate your way into it. You need to keep in mind the gate capacitance also changes with the output current (in the datasheet below it can reach up to 8000pF, for example).
https://www.vishay.com/docs/91215/91215.pdf
I would also plan to use a driver or another oscillator circuit to get higher currents. This image belongs to a blog that describes a high voltage generator to a Geiger-Müller vacuum tube, but these tubes usually consume very little power.
Hamlet
Joined Jun 10, 2015
560
Yes, I suppose I could do that, but I thought maybe the CD4047 might do this better than I could.
Do you have an example of a "purpose-designed driver"? Maybe I could link that to the cd4047...
jpanhalt
Joined Jan 18, 2008
11,087
There are, or used to be, a lot of them. Here is one I have used: http://cds.linear.com/docs/en/datasheet/1158fb.pdf
It controlled paralleled mosfets to control the speed of a Ford long-shaft tractor starting motor being used as a winch (current > 200 A). That was 15 years ago. My guess is that more modern controllers must exist.
Papabravo
Joined Feb 24, 2006
22,116
The problem with driving MOSFETs with wimpy chips like 4000 series CMOS is that you need to rapidly move charge onto and off of the gate. To do this quickly, to avoid power dissipation problems, takes a push-pull driver that can source and sink large currents.
Audioguru again
Joined Oct 21, 2019
6,826
How does that get the upper mosfet gate to VCC+10 V (or whatever)?
The circuit does not have an "upper" Mosfet. Both Mosfets have their sources grounded so the gates need pulses that are 10V for ordinary Mosfets or 5V for logic level Mosfets. The transistors provide pulses that are about 0.7V less than the supply voltage but with a high current to quickly charge and discharge the gate capacitance of the Mosfets.
Hamlet
Joined Jun 10, 2015
560
So the CD4047 supplies both negative an positive signals?
A push-pull circuit with discrete components amplifies these signals,
and helps hurry along the mosfet gate charge/discharge cycles,
keeping it out of the linear region, so it doesn't get hot or
stumble over itself at higher khz , right?
I keep reading mosfets are voltage controlled, which messes me up,
because in some applications, they need current too.
Add this in-between CMOS and MOSFET.
eetech00
Joined Jun 8, 2013
4,724
Mosfets are voltage controlled and usually only require a tiny current to function. That makes them nice to use with CMOS logic devices when you need to drive large current loads. The more voltage applied to the gate, the smaller the "RDS_on" resistance, so more current will pass thru the drain and source. Think of it as a voltage controlled resistor.
What switching frequency do you intend to use?
How much load current?
Hamlet
Joined Jun 10, 2015
560
I don't even know where to begin, that's why I'm asking questions.
I've lost some hearing, so 10khz sounds good to me! Yet, I would be happy with
1khz, as that seems the limit for iron transformers, which I have in abundance.
As for mosfets, anything goes, 50A? 110A? Maybe try 70A igbt? I'm thinking it might be
fun to try building a wild, non-sine wave, non-60Hz inverter, a big one, and push some electrons thru a big dc motor
or something, and most importantly, learn something along the way.
To me, all this boost converter stuff is new, and wonderful, and I'd like to know what I can and can't
get away with.
rsjsouza
Joined Apr 21, 2014
430
I keep reading mosfets are voltage controlled, which messes me up, because in some applications, they need current too.
They are controlled by both, but in different ways.
The voltage controls the resistance value between Source and Drain, but the current controls how fast this resistance can be controlled.
In this case, given the CMOS devices can reach higher voltages (typically 18 or 20V), they are not a problem to do the direct drive for the MOSFET you mentioned.
The "tiny current" is the core of what was being discussed earlier, which is significant depending on the driver that is trying to control it. The low power fanout of CMOS little logic devices such as the CD4047 will take a while to charge the gate capacitance of the MOSFET to its desired voltage, thus limiting the maximum number of charges/discharges per second (the switching frequency). The larger the MOSFET, the higher the gate capacitance.
Papabravo
Joined Feb 24, 2006
22,116
get away with.
You should probably learn to crawl and walk before you try to run a marathon. This stuff is not really a good place for dabblers -- it can be hazardous to your well being.
Hamlet
Joined Jun 10, 2015
560
Thank you for your concern.
I regret that my previous post may have seemed glib or naive to your reception. Online text communication often
fails at important nuances of information transfer. You may assume that I lack experience with TTL/CMOS/Logic families,
but let me assure everyone, I have handled/designed/installed electrical equipment & systems, and understand the need to apply good working practices and caution.
I will explore "pull-pull" drivers that you offered as a possible solution in your previous posting #10.
Hamlet
Joined Jun 10, 2015
560
Thanks! I am going to read up on the differences in "logic families" (ttl,cmos, etc.). Then I'll grab the iron and see how much smoke I can make.
