CD4047 Retrigger mode
natalia.t
Joined Apr 6, 2021
Hello.
I am trying to implement the CD4047 in monostable mode with the retrigger, in every diagram that I see and acording to the datasheet the retrigger can be use puting the pin 12 and 8 in the pulse input. I can not make the retrigger work and is working just as a monostable with no retrigger even if i enter more than 2 pulses.
This is the circuit I am implementing but the values of R an C in my case are: 100k and 47u
I appreciate any help.
Danko
Joined Nov 22, 2017
2,238
It works just fine.
Monostable:
Monostable, retriggerable:
35,187
Hello.
Just to be certain, what is your expectation of the meaning of "retrigger"?
natalia.t
Joined Apr 6, 2021
The retrigger that I am talking about is the one that Danko simulate. I do not understand what is happening because if i implement the monostable (the first image Danko put with input in 8 pin) it does not work at all, but with the retrigger configuration(input in 12 and 8 pin) work as a simple monostable. Maybe something about the IC? Thank you all.
