Looking for LTspice modules of CD4047 and MC14528B
Status
Not open for further replies.
DickCappels
Joined Aug 21, 2008
10,661
Asking for a friend:
Does anybody know where or from whom to obtain LTspice models of the CD4047 and MC14528B?
Thank you in advance
DickCappels
Joined Aug 21, 2008
10,661
Where is it? I just spent a long time looking through your beautiful library and was not able to find either of these chips.
cmp
sub
sym
DickCappels
Joined Aug 21, 2008
10,661
I was just informed by my friend that the CD14538 will not work in his application. We could still use an LTspice model of the CD14528 if anybody has one.
In the meantime, thank you for your help!
atomino
Joined Nov 19, 2021
8
@eetech00 I'm trying to reproduce your example of CD14538B, can you attach the schematic file together with the necessary component available like switch symbol and SW_B5.lib.
I am new for using the simulator, I start with Kicad with Ngspice, but no way to simulate a monostable multivibrator, so i am trying now to use LTspice.
In any case thanks in advance.
eetech00
Joined Jun 8, 2013
4,724
Hi
The sw_b5.lib library is not ready for release into the wild. It has issues that need to be resolved.
eetech00
Joined Jun 8, 2013
4,724
I know its been a while but I just noticed this.
What didn't work? Do you have a schematic of the "not working" circuit?
I'd like to debug the model if possible.
ericgibbs
Joined Jan 29, 2010
21,571
hi atom,
As you did not post the model .asy file, I created a model with a suffix CD14538BM, using your .txt file as a .net file.
The Circuit works OK.
The .meas are a problem...
E
atomino
Joined Nov 19, 2021
8
Very good, sorry I am new with simulator. Can you post everything you have done , so I can start with your test ?
CD14538B_3.asc, CD14538BM.txt and your .asy file.
Thanks in advance.
ericgibbs
Joined Jan 29, 2010
21,571
hi atom,
The problem will be that the CD14538BM [ M for Modified] will not be the standard model,
are you OK with that?
Place the 14538BM.asy in your AutoGenerated folder. [inside the SYM folder]
Keep the .asc and .txt and .net in the same working folder until you get more familiar with LTS.
E
Note: Remove the .txt extension from the CD14538BM.net.txt
Status
