Cd4001 NOR gate SR latch
Maria Fernandez
Joined Feb 1, 2019
11
If I have 1 SR latch all is fine, its when I add the second that I have the issue, bit baffling tbh. Its a simple circuit, I have watched a YouToob vid and he did in the same way, only 1 SR latch though.... ARGHHHH
12,214
Agreed, its high, green and yellow. They light fine at 10k. Should I try 1k?
You don't need to at this time. While a "standard" LED is not very bright with less than 1 mA of current, it is enough to see if your circuit is working. And because the LED currents are so low, driving them directly with the 4001 should not be a problem. Make a table of the input conditions and the voltages at the gate output pins so we can see what is happening.
jayanthd
Joined Jul 4, 2015
945
Why not post the Proteus simulation file ?
Your circuit behaving like this ? See attached video.
Extract the attched file using winrar 5.x and view the video file in "Windows Media Player" or "VLC Player"
