I am using pic16f887 compiler xc8 to count 20 pulses from external source by using Timer1 and compare module and on compare match, a software interrupt will enable to toggle RA6 pin.
i am unable to execute this code and interrupt is not triggering.
Mod edit: used CODE tags for readable code - removed excessive line breaks.
C:
[SIZE=3]#include <xc.h>
#define _XTAL_FREQ 4000000
#define LED1 RA0
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1
#pragma config FOSC = INTRC_NOCLKOUT// Oscillator Selection bits (INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON // RE3/MCLR pin function select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD)
#pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = OFF // Brown Out Reset Selection bits (BOR disabled)
#pragma config IESO = OFF // Internal External Switchover bit (Internal/External Switchover mode is disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled)
#pragma config LVP = OFF // Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming)
// CONFIG2
#pragma config BOR4V = BOR40V // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
#pragma config WRT = OFF // Flash Program Memory Self Write Enable bits (Write protection off)
void main(void){
TRISC0=1; //input pin external Pulse
TRISC2=0;
TRISA0=0; // LED1
TRISA6=0; // output pin
RC0=0;
RC2=0;
LED1=0;
RA6=0;
CCP2CON=0x0A;
T1CON=0x02;
CCP2IE=1;
GIE=1;
PEIE=1;
CCPR2L=20;
CCPR2H=0;
TMR1H=0;
TMR1L=0;
while(1) {
CCP2IF=0;
TMR1ON=1;
while(CCP2IF==0); // On match when CCP1IF=1, generate software interrupt
void interrupt compare_isr(void)
if(CCP2IF==1){
TMR1ON=0;
TMR1H=0;
TMR1L=0;
CCP2IF=0;
LED1=1;
RA6=~RA6;
LED1=0;
}[/SIZE]
